My Left Side Tension Belt recently snapped off. I have one on the way, however, it will not arrive until Tuesday, 6/9. Does anyone know if it will still run without the Belt on it? Thanks for the help!
I wouldn’t do it, even if it could run, once one side wasn’t moving with the other and the entire assembly wedged sideways and it kept burning in one spot.
No, it will not run with one of the side belts missing.
Thank you for the response! I figured as much. I will stay safe and not run it.
Thank you for the response! I figured as much so I will not be running it. Thank you!
