Sign for engraving
Sign
engrave center items then cut outer.
Hmm, I like the shape of the outline. Cool.
Looks great! It really is a good shape!
Thank you.
I like this shape. Thanks!
I would love to hear feed back, if there are any issues. I
I think I have just the thing to use this for, thank you for the share.
That’s lovely! I happen to have need of a little sign…
I would recommend 2 things to make sharing and using easier.
  1. Make your artboard 20" x 12" - that means no matter what system someone uses the design will stay the same size as designed when you upload it to the GFUI (Glowforge User Interface) - and appear in the spot you’ve got it designed in (which is more important when you’re using the majority of the space)
  2. I make my stroke with .007" because that’s approximately the kerf of my laser. That way I have a good idea of what it’ll look like. If you do a big fat stroke it’ll look fuller in the design than it is when it’s printed. I’m not sure what size you used since everything came through as pixels when I opened it :slight_smile:
Example of both of those in use:
Sign @larry0865_V2
Nice… Thanks :slight_smile:
Thanks!
Thank you, that is the feed back I am looking for. I will do those things.
Kind of you to share—thanks!
Thank you so much for the share. It has a lovely shape.
Great for longish text, thank you!
