Does any one happen to have any experience with Silhouette double sided adhesive sheets or similar? I would like to try an laser it, but I can’t find any information about what it is made of. No msds or anything. I searched the forum, there does not seem to be consensus on a double sided adhisive sheet that is usable or there are none named that I could find.
Fair warning: I have no idea what I’m talking about and you should ignore me, it’s your GF and your lungs.
You’re going to probably need the msds to be sure but:
Most adhesives are ok, lots are latex based.
It should be fairly easy to tell if the sheets are plastic or paper. If it’s paper then I’d say you’re good most likely. If it’s plastic… I mean it might be pvc and so I’d ask silhouette for an msds.
So bottom line - If it were me I probably wouldn’t cut it if It seemed plasticky and I didn’t have an msds.
