Appreciate the info!
- Tom
If youāre looking to have the engraved/rastered area silver, and want wood as your material, then deep engrave, spray paint in very light coats and run the board over a sander to clean up any bleed.
If you want a silver surface, with ācharredā engrave, look at this laser foil technique. Iāve posted it before, but you may not have seen it.
Edit: I may not have linked this in the most efficient way, click on the heading to go to the full post with a video on the method.
NICE! You just gained that channel a few new subscribers, Iām sure. They have some cool videos!
Just put one up on casting pewter, got me thinking about āsilverā inlays on engraved pieces.
Iāve seen this stuff popping up. It looks like magic. Spray on chrome in my lifetime. I live in the future.
Thatās pretty awesome looking. I wish they did a demo on an object that wasnāt designed to make this process look perfect. I wonder how it works with sharp edges and undercuts
What about just rubbing the whole thing down with metallic pigments, post engrave? You buff them in, so they wouldnāt get into all the details, and thereās a huge range of colors in varying metallic-y-ness (technical term). Youād probably want to seal the whole thing after.
I know Jacquard has a line of metallic loose pigments, but you can probably but them less expensively in bulk.
Thanks! Definitely the former. For the latter, I actually did see your Hot Foil post when you posted it. I thought it was quite timely for this question of mine. But Iām definitely looking for a silver engrave.
Ooooooā¦ Me likey.
Good question. I know nothing about this. Iāll certainly go learn more about it!
Thanks!
This might be foolish, but is it possible to change some of the details so that they will look too bold after engrave, right after painting?
Aw, thank you! I had no idea (bad at tracking things like that). Only a couple days off from my birthday, shoulda planned that betterā¦
Then Happy Birthday as well!
Maybe. But I think thereād be too many variables to do that consistently. I mean, what if the thickness of the paint is off in spots or in different runs. Iād have no real way to predict everything in order to achieve repeatable results.
Thanks!
I was going to suggest HIPs High Impact Polystryene, itās an engraving laminate that is laserable, you can buy it in various metallic colours
Hey, thanks!
Silver leafing would be an option too. It takes a bit to get used to but is not that hard. You wonāt lose any detail.
ā¦or possibly apply metallic wax with a brush.
