Wow! That is so cool. Thank you for sharing!
I literally bought the same metal after reading the posts you linked to, but I haven’t done anything with it yet! Maybe this will push me over that edge!
I bet you could even glue a cylinder to the backing material to make a hole for a necklace cord. You’d probably want to do it opposite the pouring hole…hmmmm, something else to test!
Awesome technique and I’ll be giving the registration bolts a try. The pewter I got is a bit higher temp so I don’t know how the acrylic would hold up, but it’s worth a try if I could get a smoother result. (Maybe I’ll try to anneal the acrylic to smooth it out. ) One suggestion though; if you’re getting bubbles or you design has an irregular shape where air could get trapped, just add small vents for the air to escape.
We did leave the masking on in one of the runs. It was surprisingly tolerant of it on the flat side, but it got stuck on the pattern on the other. I wouldn’t do it again.
We only put the baby powder on it. It got a bit stuck a couple times on the engrave, but nothing that couldn’t be overcome with a bit of care.
I’ve had good luck using silicone rubber molds with bismuth alloys. Great reproduction of detail.
I do a little pewter casting but use RTV molds. I think the melting point of pewter is a bit more than the acrylic will stand. Most pewter will melt between 340 - 450F depending on the formulation (I use Britannia Pewter). Acrylic melts at about 325F.
NIce work! That is a tempting rabbit hole. So many neat opportunities,
Acrylic has a pretty large coefficient of thermal expansion (meaning it grows a fair amount when it heats up), I wonder if it would noticeably affect larger pours. I think staying thin and small like a coin got you out of a lot of these problems.
I cast pewter and would like to offer a suggestion. It looks like you have your mold on a plate while pouring the metal. After my first mold failure (decades ago), I now put my mold in a meatloaf / bread pan (metal, not glass) if it will fit, or something larger with high sides if necessary.
I only had a failure with my mold, my friend lost quite a few layers of flesh to metal escaping the mold.
This is such a great idea and I would never have thought of it since acrylic melts before pewter, but silicone…
ah, the rabbit holes I find here …
THAT is the voice of experience
Yikes
Great job. Thanks for sharing and inspiring.
I haven’t cast metal before, but I have cast many other things (ie, chocolate and resin). If the back of your pour is flat, what is the benefit of pouring from the top in a channel rather than just leaving the back open and pouring it flat?
We tried that as well - it works ok, but the open side winds up with of a “pillowed” appearance instead of being flat. It’s a different effect, and looks fine if that’s what you are going for, but we were trying for something flatter.
Very cool! Exploration knows no bounds!
In my limited experience in casting with an open cavity, you can’t get a really smooth, flat backing. It may come out pitted and if you slightly over-fill, it will be domed. (Or outright overflow the mold.) It’s easy to sand the back and fix it, but it’s obviously more time-consuming.
Hey there… I was at burning man and a camp did this as a craft and it was really cool. They gave me a couple of forms so I could learn from it… these sources a details are excellent, thanks
Seems like a Make did a version of this recently, nice write up.
That’s a great article, thanks!
Ooh - now I want to try the coin trick but cutting that center piece using @TurboAddiction’s reeding so you get a molded coin that feels milled on the edge!
I think you’d have to use their advice for the Beskar piece of having flex lines added so the coin doesn’t stick…hmmmmmmmm
