Skipping at specific spot
Hi,
My glowforge started skipping at this location as seen in the video. It’s odd because it will go the whole range of motion anywhere before and after this spot but when it gets here it skips.
Seeing the left and right doesn’t really change when moving up and down why would it skip/wobble in just this spot?
Thanks!
Does it skip in that spot no matter what file it is engraving and no matter what material is on the bed?
Yeah, but I figured it out! The air assist fan at the back was just barely touching a hold down peg I had installed. It must have moved up just enough to slightly tap the fan casing. :man_facepalming:
