Anyone know why this would be skipping half way through?
Assuming you’ve posted the image rotated 90 degrees, then a loose belt on the X gantry.
Yes sorry it is rotated! Thanks for your input! Appreciate it!
Welcome to the forum.
Did you recently remove the carriage plate and loosen the belt? Your tension is incorrect or you have a twist in the belt.
I did just take that off. I have adjusted the belt 4 times now. My double engraving is now good but I can’t get it where it doesn’t skip. I cut 7 magnets just fine and then it does that.
Are the teeth of the belt facing in?
Yes they are
