Small circular shelf for figurines
I made this shelf for my nephew to display some of his figurines. I ended up cutting 30 (!) layers of 3mm plywood to get a depth of 90mm. It’s about 12” across.
I cut up the shape into pieces with two versions of cut pieces so that the cut areas would be offset by alternating the two versions during assembly. One good idea I had was to label and score every piece #1-9 or A-G to make assembly easier.
As I was gluing all the layers together, I thought there’s probably a more elegant way to make this shelf, but I will say this version is very sturdy!
I bet he loves it! You did a great job - but 30! layers???
Way to go! I’ll bet you’ve got a happy nephew. Good looking design–you were dedicated.
A lucky nephew! The unique style makes it extra special.
I made a “tube” like that once, I played around in inkscape to come up with the most efficient way to use material to stack up layers like that with dozens of smaller segments. I made it to replace a missing part on a piece of furniture for a friend, I have no idea how may “layers” it actually took but it was about that. I used cheap leftover MDF becuase the whole thing was painted and aged anyway…
Yes I had the same thought :joy: I didn’t realize I needed that many layers until I was already committed so I just had to keep going and finish it.
Very cool design!
that is adorable!!
Looks great. That’s a lot of layers
Awesome job!!
Very nice design!
I’m sure your nephew loves it! That’s a lot of work, but definitely looks worth the time and effort.
