I purchased my Pro on January 17th of this year and I do not have the snapmarks on my machine! Is there anything that I can do to get them?
Also, yesterday when I was trying to use the pass through, I realized that my alignment was on by 1/8 of an inch! What can I do to fix this issue so that I can cut larger projects to where they will align up right?
it’s know issue that:
a) not everyone has snapmarks. Join the crowd, i’m one too…
b) alignment can be off up to 1/4 inch. The camera is a fish-eye lens and the further you are from directly under it, the more ‘off’ it might be…
Thank you so much for your interest in Snapmark. We are really excited about it, too!
As we mentioned in the Glowforge Community topic, there are a lot of factors that go into setting up testers with this experimental feature. The engineering team is determining each step of the rollout. Unfortunately, I can’t affect that process for you. If we do make it available to everyone, or if your machine is chosen for the rollout during the testing phase, you’ll see the Snapmark icon appear in your Workspace. In the mean time, keep an eye on the community for more information.
The software on your Glowforge is responsible for ensuring that the print lands on the material in the same place as the preview. When you’re done with a print, let a new image load. If the print appears on screen far from where it was supposed to go, you may have an alignment problem.
Most alignment problems come from the material being closer or farther from the camera than expected. While the software is still improving, you can take these steps for the most accurate alignment results:
Use Proofgrade materials.
If you don’t use Proofgrade materials, use a precision set of calipers to measure your material, and enter the thickness in the “uncertified materials” dialog.
Use material that is not warped or tilted.
Place your design near the center of the bed.
Clean the area underneath your crumb tray, particularly the four indentations on the floor.
Reboot the machine. Alignment can drift over time, particularly if you bump the head of your Glowforge while removing material.
We’d like to have you try a few troubleshooting steps for us:
Turn off your Glowforge.
Check for small pieces of debris or dust.
Check the lower door to make sure it closes all the way. It may require some force to open, but open it, wipe any dust off the edges, and close it all the way.
Remove the tray and clean any dust or debris from the surface underneath. Pay careful attention to remove all debris from the four dimples where the tray rests.
Check the lid to make sure it closes all the way. Small particles of material, such as dust or debris, can prevent it from closing completely.
Check the surface your Glowforge is on to make sure it’s flat. Ensure it is not twisted slightly and that there is no debris propping up one side of the machine.
Turn your Glowforge back on.
We included an extra piece of Proofgrade Draftboard with your materials shipment for troubleshooting. Place the Proofgrade Draftboard in the center of the bed and print the Gift of Good Measure using the default settings.
When the print finishes, leave the lid closed and wait until the fans stop and the picture updates. Without moving your artwork or your material, take a screenshot of the Workspace to show us the difference between the artwork placement and the actual print placement. Make sure to include the rulers in your screenshot and show as much of the bed as possible.
Mac: Press Shift-Command-4 and click and drag a box around your image. You’ll find the screenshot file saved on your desktop.
Windows: Click on the Start Menu and type “snipping tool”. Open the Snipping Tool > New then click and drag a box around your image. Click the Save icon and name and save your file.
Send us the screenshot along with the date and time of the print, and we’ll investigate.
Should you finish all of these steps, and find that you have an alignment error of more than 1/4", please contact us so we can investigate.
