Posting this here because it’s not really a support issue. I’ve been trying to get a file to work with snapmarks but so far no luck. I thought it might be the printer I was using so I’ve tried 3 different printers now and no dice. Still having an alignment issue on all printers. Here is a picture to show the issue; the cut should be right on the edge of the black and currently the top lines up well but the bottom is off to the right. It’s off on both sides but obviously it shows up more when it is leaving white rather than cutting extra black.
It does this on all the files I have tried (same layout but different cards). My current process is make inkscape file, turn off cut lines and save it as a PDF. Then Print that PDF and use my SVG file with the lines turned on and the pictures turned off to cut it. The PDF and SVG are attached. Could anyone with snapmark give this a try to see if it is just my machine or the file? Thanks.company card sheet backs.zip (9.3 MB)
company card sheet backs pdf.pdf (8.0 MB)
