Can I use a tablet other than an I pad, if so what software do you use to design with?
To run the GF you can use anything that has a web browser.
As for designing, which tablet OS that’s not iOS did you have in mind?
Thanks for the answer @ekla, that’s right.
Here is a little more information about the hardware and software needed - You can use your tablet, you’ll just need an up-to-date version of Google Chrome, Firefox, Apple Safari, or Microsoft Edge.
You can design with any software that saves a PDF, including dozens of choices like Adobe Illustrator, Inkscape, CorelDraw, Adobe Photoshop, GIMP, Autodesk Fusion 360, and Sketchup. Glowforge can print JPG, PNG, SVG, PDF, and other file formats. To print a file, just drag-and-drop it directly on our app, and then adjust the preview to your liking.
