A basic coordinate system not scales… a machine home or zero or something similar. And some functionality as follows:
The ability to make a 3 inch by 3 inch square with an 8mm(.3150) hole dead center or on a location from a set zero. I would like to add .25 radi to the corners of the square. A 30mm diameter circle- or a hole pattern with 30mm spacing. (Your text here) on a 3 inch radius. Inside and outside radi on an arbitrary shape… Etc….
These are very common features in industry. And would vastly expand the capabilities of this machine.
I would love the ability to draw conversationally. Please look up what conversational programming is! It would be extremely easy to add to your existing premium service! Which I have but won’t keep unless I see something like this. The ability to draw a line in or line out - a square, arbitrary, or circle shape… basically telling it to hold the dimension to the inside or outside of shape… And let it figure where it wants to ramp in and out, and give the user a little more control. Please let me know if this is something you have any interest in at all. I can help if need be. I do not want to be forced into adobe illustrator or inkscape graphical software- it’s not optimized to do these things in my experience and I’ve spent weeks learning it.
-steven-
