Soot debris
Has anyone found an easy way to clean the soot off the side and engraved areas? I am trying to waterproof wood after cutting, and the soot is just coming up and ruining what i have done. Thanks for any help!!
Hello and welcome to the community. I’ve not had to worry about this, but I think you’ll find some good help when you use the search function.
One thing I recommend working on is minimizing the char by making test cuts with that specific material in your specific machine to find the best setting to use. You want to find the fastest setting that will cut all the way through reliably.
What I often do is make a very small test cut of a star shape (because of the corners) in the corner of my material. Use different settings (I usually do increments of 10 and then increments of 5.)
