I tried the Spiral Drawing set and it is not a good design. The “teeth” do not match up and some are not shaped correctly. It does not flow at all. I am glad I didn’t try it with acrylic first! This design needs work.
I’m so sorry the Spiral Design Set has uneven teeth and doesn’t work for its intended use! I’ve filed a report for the team, and we’re working to fix the design now.
I really appreciate you pointing this out! We want our catalog to feature top-quality designs for all of our customers, and your contribution helps.
It looks like you’ve also emailed us about this and I will follow up with you there, so I’m going to close this topic.
