Here is the Square Spiral Bowl and Cake Stand that I posted in the MOAG Category a couple of weeks ago. This was done in PG Medium Walnut. To change it from a bowl to a stand just flip the base over and attach it. I tried to get it on one board but that didn’t work. Print 2 additional square leg attachments. (Note: everything should fit pretty tight. If the center of the bowl doesn’t stay down on the peg just rotate the bowl 90 degrees and try it again)
This was created in Illustrator.
If you come up with improvements make sure post them!
You’re saying you couldn’t quite fit it on 1 sheet of pg. When I open the file, it seems to fit just fine with room to spare. The bowl part itself comes to 8"x8", correct? or are we not speaking the same length? I do have my Inkscape set up so I don’t usually have any cross platform issues. Thanks!!!
