Hello Glowforge Community!
This is my first time posting since I’ve received the machine back in September since it has been running smooth this whole time. Unfortunately, I’ve noticed recently that when I score/cut circles, the start and end points shift in the x-direction, making them not line up where they should:
The laser begins on the right-most point on the circle, continues in a clockwise direction, then ends back at where it began…only a little off in the x-direction. It seems to randomly pick a negative or positive x-direction from where it starts. This also does not happen on every circle I cut (see the outermost circle); I have had some prints where 2 circles are to be cut (with concentric circle scoring inside of them) and one circle will be completely fine, whereas the other will have all concentric circles with the x discrepancy.
I have cleaned the machine per the online instructions and have even re-tightened the x gantry belt. I also tried saving as a “plain svg” from Inkscape instead of “Inkscape svg” (I use Inkscape for all my designing because, well, it’s free!) I’m not entirely sure what else I should test or how to address this problem. All input is welcome!
Cheers!
