I had the Glowforge quit cuts mid-cut over and over at about 1:45 CT today. I had a piece going through the pass through. It had already finished the engrave and scores and was doing simple cuts when it began stopping. It would stop and return home. I opened and closed the front door to make sure that the safety magnets were acting properly. Started the job again (after deleting parts that were done from the GFUI). Again it quit after a short cut. Repeat. Repeat. Repeat. I ended up not running the rest of that job.
Can you check the logs and see what HQ sees happening? Thanks
Rob
