Ok so the issue is I have a refurbished pro and only had it for a week, it was printing fine but then all of a sudden it stopped in the middle of a print and the yellow light came on. i cleaned and did reseat, looked at the pins to make sure it moves back and forth on the print head, fans are fine, it will print intermittently then yellow light it will be stuck on focusing. if i put the arm under the camera in the middle and turn machine back on it will then focus and print. once its finished printing that job it will do the same thing, stuck on focus? help please.
The yellow light indicates a temp issue, however it can also result from a loose connection with the white ribbon cable at either the print head or at the circuit board.
