I have been running into difficulties today. About 50% of the time my file uploads without issue. The other 50% it takes forever. I have tried checking my Wi-Fi connections, cleaning the lenses and restarting the Glowforge and the laptop. Is anyone else having this issue? Does anyone have any other suggestions?
I have not had problems today. Have you tried a different browser or tried just dragging your file into the interface rather than uploading? Could the problem be the file, or is it one you have used often?
Thank you for your suggestions! I am trying to use multiple files (earrings) on one print. When I try a smaller section I am having more success. I wonder if one of the files has a problem. I will try to cut one design at a time and see if that helps. Thanks!
Unfortunately, it doesn’t matter how many I try suddenly nothing prints.
Hopefully someone from support will reach out.
Only if you have emailed them.
They no longer participate here.
Thank you! I will email them now.
I cut and engrave both sides of 77 objects on a piece of material at a time without issue. They are detailed pieces with text and a logo. There’s no reason you shouldn’t be able to cut multiple earrings.
