Svg double lines
Hello, just looking for help with a puzzle. I work on an iPad because I don’t own a computer, so my options are quite limited and I’m not sure if I’m even able to do what I’m trying to. Basically, I have an Svg file that when I upload it to Glowforge, it doubles all of my lines, which isn’t really what I want when trying to do a precise puzzle. I can’t use gimp or Inkscape on my iPad, so are there any other options available to me, or am I just going to have to deal with it cutting things wrong? I’ll attach a screenshot for reference.
it looks like wherever you got that (or however you created it) created each individual puzzle piece with its own shape and then a separate outline around the entire puzzle. so you’re essentially cutting each piece individually, which is both inefficient and likely to make a very loose puzzle.
try a different generator, like this one: Jigsaw puzzle generator ; which originally came from this thread.
this generator creates an outline cut of the entire puzzle, and then creates a series of horizontal and vertical lines so there is a single cut line on each edge of each piece.
You’re definitely not alone in using an ipad - and yeah, @shop’s suggestion is the way to go!
How frustrating. I made it on procreate and then converted the file. It’s for a small child so I wanted very specific tab types for the pieces. Thank you for the recommendation!
On another thread a few other design programs for ipad were mentioned:
