I am having an issue similar to what was described here:
when I bring it into the glow forge UI it wants to cut around the entire image
I can’t figure out where this image outline is coming from; what am I doing wrong?
It would appear that the outline is set to engrave, if set to score or ignore you should be ok,
but there isn’t a outline to the image in Inkscape as far as I can tell but its making it PART of one of the groups in the image that I want cut so I don’t have an option to set it to ignore…
You can only engrave images. vectors can be engrave, cut, or score
forgive me for using terms loosely… its a VECTOR image does that make you happy?
my problem still remains that in my VECTOR image file there isn’t a border around the outside of the VECTOR image file but one is appearing when I import it and I cannot figure out why its appearing nor can I figure out how to remove it
I just downloaded it and it’s not showing the border for me when I upload it to the GFUI. I did get this error message, though, which might have something to do with what’s happening:
It does look like you might have your settings set to ENGRAVE instead of SCORE – that would make the image appear to have a rectangle around it.
No need to be snippy…people are just trying to help.
Other than the CSS errors pointed out above, I don’t see an issue with your file.
What settings did you have for each step? I had the holes set to cut, the text to engrave, and the racetrack to score.
I don’t know what that error means or how to fix it
I hadn’t set the settings because I was afraid it was trying to cut so I have been troubleshooting that and going crazy
as I change the settings the box around the entire image changes to match the holes color so im not sure what its trying to do
Without knowing what settings you are using, there’s no way to tell.
With what I assume are appropriate settings (that I posted above), i can’t reproduce what you are seeing.
im not sure it matters what I have my settings set to can you explain why it matters; no matter how I change them the line still appears around the image
also can someone explain why I don’t have the add art option?
The file you uploaded here in your first post is not the one you have in your UI. It only has three print steps. Without that same file, it’s impossible to determine what the problem is.
The Add Artwork option is “behind” the (+) menu at the top.
I’m not sure what it’s going to do either, but that is because of how the file is constructed.
You have a lot of sections of overlapping vectors in it, and they are the same color, and that will tend to cancel things out, or cause errors.
I ungrouped everything as far as I could and deconstructed it to show you…the red Score sections are actually closed and overlapping…that can throw a wrench in the monkey works.
Areas with the orange brush strokes are where the segments of the design overlap, and that might be messing things up. If it does print, it’s going to double burn there, so you might not want that to happen. Try to fix those so that they are just one vector line. It will probably get rid of the outer rectangle. I think the cancelling effect is creating open paths, and the program is trying to close them.
(First time I’ve seen it…it’s an odd effect.)
I just added one more thing to the same file… for all intents and purposes the problem is STILL in the file I am just continuing to try to work while I get some help understanding what’s happening
There is nothing wrong with the file you included in the original post, so it’s likely a problem with the other files you added.
how so when the problem existed before I added things…
when I use that file I still see a border on the image
You mean that orange line that is going to cut-out the board? I thought that was on purpose.
