I have a simple .svg file that I exported from Fusion 360. That one cuts correctly.
However if I open that .svg in adobe illustrator and modify it (say add some text), then when I save the .svg back out it’s mysteriously corrupted. The new .svg loads into the glowforge web interface fine, and even looks correct. However when I cut on glowforge mysteriously some portions of cuts are missing, cuts seem distorted, and in some cases brand new cuts appear.
Super weird.
I believe this is a problem I’m seeing with other adobe illustrator .svg’s I’ve saved, including those authored entirely within adobe illustrator itself.
Anyone else see this behavior? Pretty dumbfounded since it previews correctly. Is there some difference in how the preview code works vs. how glowforge actually cuts?
