When I start up the GF the teal light does not stay lit. Yesterday when I had my GF running, it connected easily in the garage 50 feet from the router. Because of the heat in the garage, I moved it indoors and 10 feet from the router. My laptop is connecting readily to the router so I know it is working. I have restarted the GF several times, and when i moved it upstairs I followed the directions for safely packaging it and unpackaging it. the head seems to be working well and moving freely. Any suggestions?
If you already setup your WiFi, there should be no teal light. Briefly there should be a white light, but teal only represents WiFi Setup mode. So if you’ve already gone through that process, you should be all set.
Thanks so much. I just tried my first project and it worked.
Hooray!
Now get outta here and go have fun with it!
Thanks for the answer @Tom_A, that’s right. I’m going to close this thread - if you have any other trouble, go ahead and post a new topic. Thanks for asking about this!
