Overall, they are very similar. The “Map grays to power” is fairly flat, which isn’t the best for trees. I’m thinking I’ll go with one of the dithered options, to give them more texture.
I think you will see a much larger difference between the dithering options if you engrave a photo. One of the key reasons to use dithering is to avoid banding and flat spots in gradients.
You need more variance in the grays within each tree for “map grays to power”, I believe. Since it’s uniform gray for a whole tree, it will be flat. If you had variance, for example, a black and white conversion of a tree, where the front leaves were lighter than the back leaves, you’d have more perceived depth.
Would pulling the greys out across the white to black spectrum help? I can’t recall the term. For example on a greyscale of 0 to 255 it would pull values 100, 101 , 102 into 0, 127, 255. Like grading on a curve for all C grades on a test. Someone will get an A and someone will get an F.
obviously i do not have one yet, but does anyone know how the map power feature works? e.g., do you set power and black is equivalent to the power level that you set? then whatever percent of black a grey is is equivalent to that percent of your set power, or is black always equivalent to ‘full’ power?
From the setting you have available, it appears that you set the max power and speed, then set what the min power will be. I’m assuming it will scale appropriately from there.
@palmercr, it seems like you can set it to Full Power for the engrave, as well.
It is very confusing then because we are told there is a gap between 100 and full. If it can give 256 equally spaced levels ending in full why then is there a gap when not raster engraving?
It would be interesting to set min to 100 and max to full and see what a linear grey scale looks like. Or GF could just document what the controls on their machines do in the manual instead of us having to guess or reverse engineer it.
Very similar on wood. Try those same patterns on black slate or granite, and you’ll see a far more dramatic difference between the three modes. This is because stone is a far more ‘binary’ material to work with, so you should see the pixel patterns much more pronounced in either Floyd-Steinburg or Dithering. If you try Map Greys to Power on stone, I don’t think you’ll see a very dramatic effect.
