Texting on glowforge
Is there anyway to continue text on GF without having to use another application? Like if I want to type an address, I have to go line by line it doesn’t let me just continue typing onto the next line. It is really annoying to have to go line by line and redo the settings each time. Wondering if anyone has figured it out or if going onto another app is the only way for it to recognize the lines of text are together?
Thanks!!
No is the short answer. If you have addresses or multiple lines, it is faster to create it elsewhere, save as a pdf and drag it onto the interface.
I thought so…Thank you!
Yup, this is my biggest complaint about the pro GFUI right now. Multi line should be a thing.
would make sense and things a lot easier!
I can’t help with the multi line, but if you copy and paste your first line, your settings will remain intact…that should save you a little bit of time!
That had never dawned on this supposed veteran user! Thanx!
Do wish they’d update with multi line text though.
That said, it is just best to break out another program if you need to do a lot of text.
