The Glow Forge goes thru its first 4 Positions when Centering than after that its Wacked , Grinding , screaming , any ideas as how to reset it.
Thank you ,
Thank you ,
The screaming wheel probably has a problem that need looking into carefully, Get lots of photos and post.
Oh no, I’m sorry you’ve hit snag.
For us to better understand the circumstances around the trouble, could you include a video showing the grinding noises you’ve described?
We look forward to hearing back from you!
I got it working , I had to restart it like 10 times before it just found the Head after the electric went out. Its no easy fix when that happens but its working again until next time.
Thank you
yea, you manually needed to ‘home’ it;
With the power of the unit off, gently push the gantry back to the back, and then push the print head (again gently) all the way to the left.
I had the same problem, but it wasn’t the GF, it was a truck hit a pole!
Thank you for the update. It’s great to hear that you were able to get back up and running! If you run into trouble again, or have other questions for our team, please reach out and we’ll be happy to help.
