The Glowforge app keeps pausing
Today is the first time I have used my Glowforge app since it updated the UI. For some reason, mine keeps pausing mid print job and is Cooling down. A twelve minute job is taking over 30 minutes. Is there something going on with the App or am I getting ready to lose a Glowforge machine?
Your issue lies with the machine, although that doesn’t mean it’s terminal. You’re describing a cooling issue, i.e. a dirty fan or exhaust port, reduced airflow due to blockage, or clogged filter if you’re using one…
Thanks so much. I discovered after the post that I neglected to turn on the inline fan.
Glad you figured it out!
You probably thought of it right after you posted it, right? It happens to all of us at some time or other.
