I’d like to try making some furniture, but I’m pretty clueless on getting the settings right… Soooo, what’s the thickest plywood I can cut (on a basic) and what settings should I use?
Generally 1/4" is as thick as is recommended. You might be able to go thicker.
Searching for this is pretty easy, not sure what you tried (if anything), but these two searches are full of results that you will find relevant:
https://community.glowforge.com/search?q=thick%20plywood%20settings https://community.glowforge.com/search?q=cutting%20thick%20materials
