I must be missing something. I was trying to figure out what material she used for those can holders.
is there some “info” button I’m not seeing to click on?
Should be medium draftboard, IIRC.
(Any medium PG ply will work, but it gets pricey.)
and in terms medium is 1/8" (thick being 1/4")
FYI, usually the material thickness is in the name of the file. I don’t have that file, but for example “(1. Medium Plywood) Counting Down the Days Calendar (24 Days)”
well isn’t that just fabulous. I have medium draftboard from those fine folks at BLICK.
thanks Jules!!!
I am thinking about making a version that is stackable.
Is that the same kind of Draftboard that Glowforge sells? (Which is actually a kind of MDF).
Just checking…I’m not sure Blick uses the same terminology, although you can always try it…it needs to be 1/8" thick and closer to 0.134", which is what my DB swells to here.
Just be sure to have some glue and clamps on hand for slightly thinner materials.
you know. I have to look at that more carefully. I have PG draftboard I got a while back. Well I have 1/8 material of various types. as I was typing this it just dawned on me what I got from BLICK was chip board. Duh.
I do have a couple of large sheets of the PG draftboard for sure. bought back in the old days when they had stock
and I have about 30 quick release clamps, along with pipe clamps, bar clamps and C clamps.
so if I just get it close I should be ok.
