Tic tac toe valentine. Is this cutting out two games?
I’m making the valentine tic tac toe. It looks like it’s cutting out two games
Welcome to the forum.
The base is two pieces to form the correct depth. One is solid and is engraved, the other heart has the squares cut out.
Thank you. I wasn’t sure due to it engraving the words on both pieces
It should engrave the words on only one piece. Does your interface look like this?
No. It shows two identical images one in blue and one in pink. I think it’s cutting out two games. I’ll have to get another piece of wood for the backs. It’s been cutting for almost 2 1/2 hours. It has 35 minutes to go
I don’t know how to put pic on here to show you
Just drag it and drop it in your post. :wink:
You can capture a screenshot and then drag that into a text box.
I was looking at the wrong design. This one shows two games, and cuts two games. You personalized each one. If you want/need a backer for both you will have to cut another blank backer or a backer with the hearts engraved.
I did. Thank you for your my only problem was after hours of cutting, it had about 12 minutes left when it went crazy and started making wiggly lines and it started cutting in the wrong places. I paused it. I finished it by adding cut lines where they were supposed to be.
