I just cleaned my air assist fan and now I can’t tighten the bolt on the right side of the machine, I think it must be stripped…what do I do now?
Are you referring to the bolt that tightens the belt pully?
There is an inner threaded piece that may have slid out of the way. Gently lift the left side of the machine and listen for it to slide right or get a light source and see if you can see it slightly to the left of where the pulley wheel screws in.
