TIP Homing will fail if GF is exposed to direct sunlight.
I couldnt get my GF to home, one i pulled the curtains it worked. Turns out it cant home while in direct sunlight.
It gets confused if it sees its shadow from any bright light.
Yes, this is true. The GF uses cameras to home and if you have any bright light coming in the shadows will confuse the images. This has been known for quite a while and is one of the first troubleshooting steps when your GF won’t home correctly.
Good reminder! My GF sits right under a south facing window without a shade, when the Sun shines down I cover the forge with some black foam board during calibration or other camera operations.
I’m glad you resolved it! I’m going to close this thread. If you run into any other trouble, please start a new topic, or email us at support@glowforge.com. We’re here to help!
