My first GF gift! The Sasquatch is a running joke for the recipient.
Two things of note: I’d forgotten that the circular top piece is actually cut upside down so I ended up drilling through the pivot point. I should have flipped this piece over before running the fur pattern score.
On the reverse side of only the two circle pieces with the furry pattern score there are some fine dots, seems that even on “Draft Score” the beam burned all the way through at the pointy corners.
