Yeah, this one came out as intended, but I’m trying to write a fully parametric version in Fusion 360 and I keep cratering the structure! I could try for something that didn’t slot together from so many directions, but the only thing that makes me dig down harder on something is to continue to blow it. (At least I’m learning a lot.)
Failing just means you’re learning at an accelerated rate. I salute you. Failure at my house usually results in a Rapid Unscheduled Disassembly. One of the first things parents say when they drop their kids off to play with my son is “Why do you have so many fire extinguishers?”
Turns out you’ve got to be reely reely careful to not leave off your constraints when you’re working with lines instead of rectangles, because what looks like it might be a horizontal line isn’t necessarily.
Correction: until it turns black.
Black = fully constrained.
Blue = unconstrained.
If you want to nerd out even more:
Pink/Magenta = projected geometry (either from other sketches or your 3D model)
Green = geometry that is manually locked/fixed
