This is what I have done the first two days of forging with Glowriosky.
I am really impressed. is all I expected it to be and more.
Question: Has anyone else printed the catalog coasters and if so how did you glue the outer rings and base together, and what if anything did you waterproof them with?
This is my next project. I need to duplicate this for all of the different pen sizes that I make.
Great first couple of days! Keep it up!
I would probably just use CA glue to be quick for the outer rings.
And I might not waterproof at all…you want them to be able to absorb some moisture from the beverages.
I have. I used Aleene’s Fast Grab Tacky Glue and some spring clamps overnight because I only know one trick. We have so many coasters lying around these are unlikely to get wet, but after looking at them for a couple of days I decided to spray a bunch of coats of polyurethane on. I don’t really know if that had any meaningful effect on the engraved parts.
