Two sided etching
Thanks so much for your help, how do I change colors? Also, I am trying to cut through ¼” plywood and I don’t seem to be able to cut all the way through. Any suggestions? Thanks, Dale
You change colors in your outside graphics program. As for cutting through 1/4" material, if you use the search function of the forum you will find lots of posts regarding that thickness of plywood. The problem is, that material is quite variable and subject to voids, glue spots and knots. Some non proofgrade plywood simply won’t cut with a laser. If your cuts are almost through, you can low the speed down slight.y.
Since this discussion is not really an issue for Glowforge support personnel, I will move it to out of this category.
