Attempted to run a job using material settings I created with Glowforge Material Manager Chrome extension. Have used these material settings at least a dozen times. Used these settings the last time I used the Glowforge, last Friday.
Now I get the error message: ‘Unidentified Material in your Glowforge. Select a material or specify material height. If you’re using an uncertified material’
If I click on ‘specify material height’ it prompts me for a height and then wipes out the material settings.
If I click on ‘Select a material’, then I go back to the select material list, select my material and I am back to where I started.
Are the materials created with the Material Manager no longer supported?
Tried restarting the app.
Made sure material manager definition had material thickness specified and every setting has the Focal Offset specified.
None of the custom settings work. GF settings do work.
