Does anyone have any experience cutting Unisub MDF board that is used for sublimation? Would like to know what settings would be. I am using the GF Plus. Thank you.
You’d have to test it, and there are a few “new material tests” post here in the forum New material cut test method , but I usually always start with proof grade settings. Try the proofgrade MDF settings of the same thickness and see if those work.
Thank you.
