After having my custom ventilation system running for a bit over six months, through the hot summer, I had one failure: the power supply for the central control RPi died. Everything else has been running pretty much perfectly.
I used the Glowforge this weekend to engrave slate coasters and it was so nice to be able to just turn the machine on and have the ventilation system automatically open the gate and turn on the fan. It was so much quieter than the filter box! I can actually be in the room with the laser running.
I’ve also used the solder fume extractor both while soldering and while mixing epoxy and it worked great. The filter life is estimated at 96% so that should mean I only need to change the filter every couple of years at this rate.
That would be bad, I’m lucky I rarely get the wind coming in. It works great. And, we live in the country so don’t have to worry about neighbors smelling it.
Yeah, we live in the country too, and although that window is on the side of our closest neighbor, the wind blows away from their house so it wouldn’t hit them anyway. My only problem is that it blows it back into my craft room. I do have a OdorStop air filter right next to where it vents out though, so that does help catch a lot of it when it does blow back in - as long as I remember to turn it on!
