I updated the engraving with the deceased rappers and completed an NFC EAST and NY Giants engraved cut.
Very nice!!
Thanks. I’m still learning.
You’re learning quickly!
For the really tall one, you might find the light transmits better if instead of cutting in the edges above NFC - EAST you kept them as a column up - it gives the light someplace to go.
and I’ve not tried it myself, but a bunch of folks swore by doing the engrave as a gradient (grey at the bottom, black at the top) allows more light to get all the way up. Maybe worth playing with
(there’s a bunch of info up-thread)
What did you use for the rappers? Materials same for rappers and headstones?
Edge lit acrylic is done with a single sheet of acrylic that the light passes through
Thank you. I will give it a try.
