Uploaded svg photo has too many steps and I can not seem to select them all at once to set engrave parameters
SVG Steps
how many steps there are is determined by how many colors are in the design. so in your editing program, you should make sure all the objects you want to use the same settings are all the exact same color. not just visually look the same, but are the same RGB or CMYK values. even 1 number off creates a new step.
there is no way to select multiple steps in the GFUI and change their settings in one pass.
Although there should be. This is one of my biggest annoyances with the ui.
i won’t disagree with you.
This is one of my oldest hopperized wants. Back when we were all working up the test material patterns. Select a row, right click, this burn power. Select a column, right click, this speed. Or selecting whatever, right click, assign X (value).
Thank you all for your feedback!
