As convenient as the copy/paste workflow is, this is one of the reasons I don’t engrave from vectors directly. You have to cross your fingers and trust that they will be rasterized on the Glowforge server to come out exactly the way you want, and the more complex the drawing is, the more chance there is for something to go wrong.
Whereas if you rasterize in Illustrator, you can be sure of the exact bitmap that will be used, with no shenanigans.
copy/paste from AI into the GFUI has never worked for me. Sounds like it would just piss me off though.
for your crest file, I just tried doing a Simplify operation at 98% curve precision, and It took the node count from 49,673 down to 3,216 without distorting the image much at all.
With files like this, that have way more nodes than they need, I almost always try Simplify to start (around 95%-99% precision) to see if the results are acceptable.
it took less than 10 seconds to process in the GFUI, and looked like it came though fine, although I didn’t run the print. No weird thick lines though.
