I’ve been making lots of things… and so far so great… until today. I’ve been using files with vector lines in multiple colors to make different Manual Cuts with different settings. Always worked so far.
But for some reason with my new file, it only gives me the option of Manual Engrave.
I compared two files - one that goes to cut menu and one that goes only to engrave:
The files are the same type -pdf
The lines are using the same 2 colors, same thickness, and no fill.
Same number and size of objects/paths.
I even took one that wasn’t working… simplified it to 2 circles… didn’t work. I redrew those circles over the exact same spot… removed the original and the new circles work fine. I’ve tried copying and pasting the non-working ones into a new document.
The real file I want to cut has a bunch of objects - so I don’t want to have to redraw it. But clearly it isn’t the number of objects, because just using even one object from the non-working file doesn’t work.
Any ideas??
