Does anyone have any tips for getting warped PG boards to lie flat? My neodymium magnets aren’t strong enough to bend wood
Make some of these and pin the wood down:
You can stack them flat with heavy weights on top for a few days and see if they flatten at all. If the warping isn’t crazy, holddown pins like @beerfaced suggested will work great. If it’s really bad, reach out to customer support, they warranty the materials and will likely replace the bad sheets for you.
Thanks for the files! I will do that
While you can try to flatten warped sheets, it’s never really worked in my opinion. Unless they’re stored for a while under pretty heavy weights.
Hold down pins for the win…
