Was Centering - Now it’s not
Help! My machine was working fine and now it will not center. I saw that in another post the person had to check to see if the lid was properly functioning and it has been. Here are photos of the inner lid. It starts and I hear a quick whirl of the motors but that’s it. Nothing happens.
It literally was working a day ago and now it’s not. Any help would be appreciated.
I’m so sorry to hear your Glowforge is not centering.
I extracted logs from your Glowforge and it looks like it was able to connect successfully to your network, but it may be having trouble maintaining a stable connection. When this is the case, you won’t need to go through Wi-Fi setup again, but you may see an “Offline” message or not be able to calibrate.
  1. Turn off the computer, phone, or tablet that you’re using
  2. Turn off your Glowforge
  3. Unplug your modem
  4. Unplug your Wi-Fi access point
  5. Wait one minute, then plug everything back in and turn them back on
  1. Improve the signal path between your Glowforge and your Wi-Fi access point
    Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
  • Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
  • Relocate your Wi-Fi access point closer to your Glowforge
  • Move your Glowforge closer to your Wi-Fi access point
  • Install a Wi-Fi range extender closer to your Glowforge
  • Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
  1. Reduce electronic and Wi-Fi interference
I hope this helps. Please let us know if you have any other questions.
I did all of this PLUS I checked all the cables, reconnected the printer head cable, dusted the machine and cleaned the lens. FINALLY it’s working again.
Thank you for your help!!! It is greatly appreciated.
Hello @sandra_rivas
That is fantastic news. I’m so glad to hear that your printer is back up and running again. Going forward should you run into any troubles along the way, please do not hesitate to reach back out to us here at Glowforge for assistance. We’ll be available and happy to provide you with assistance when needed. That said, I’m going to close this topic/chat. Thank you.
