Everything was operating smoothly yesterday, this evening not cutting or engraving. At a roadblock.
Trouble shoot all I knew to do. HELP
Remember you are asking people who don’t know what that might be to help. Details would help. the more the better.
Which model Glowforge do you have?
What troubleshooting have you already tried?
What happens when you print a catalog design on Proofgrade material at Proofgrade settings?
I have a pro, cleaned all the lens, removed the head, cleaned it. Cleaned the fans. I used a maple proof grade to cut and engrave. No laser light that I can see.
I also check the engraving triangle to see id that worked no luck
It sounds like you need some real tech support then. You can call them or open a ticket at https://support.glowforge.com
What is the glass tube that lights up called? It could be a loos wire or this tube. My gut feels like it may be this tube. I do not know the life expectances of any part on this machine. I too, have a plus that is running just fine. Any suggestions?
It’s just called a laser tube! And it’s more likely to be a wiring or power supply issue than the tube, since sudden failure of the tube is extremely rare.
How would you go about narrowing it down?
You should definitely talk to tech support to confirm that you have a hardware issue. But if it’s either of those things, the resolution would be the same, as neither is something they’ll help you fix in-home. They’ll want the machine back and offer you a warranty replacement, or discounted refurbished replacement, depending on your warranty status.
There’s also a third party repair company you can reach out to for advice or a quote: https://support.glowforge.com/hc/en-us/articles/25839457911195-Repairs-by-Wiregrass-Technologies
A common problem is not putting the mirror back straight. That can create a real mess when you start back up.
This topic was automatically closed after 29 days. New replies are no longer allowed.
