Wavy Engraving (Please Help!)
Engraving becomes very wavy and I cant figure out why. Tension on the belts are fine and no cracked wheels. I even slowed down my engrave speed with no resolution. Went through and cleaned machine thoroughly with still nothing helping
Did this start suddenly? This is almost always a cracked wheel or incorrect belt tension.
Pretty sure that your belt tension is not as fine as you think it is, and from the way the shift repeats at distinct intervals I would guess that you have either a cracked wheel as well, or a chunk of debris stuck in the belt teeth.
Agree with above. Has to be something to do with the belt.
