This is not a showstopper, although it is mildly irritating – I’m mainly posting this as a sort of “heads-up”.
I have a series of very simple SVGs that I use to cut specialized washers. Each file is just four circles.
As of this morning, the GFUI has trouble rendering these. If I import a file, the bed preview shows two solid black circles and claims there’s no artwork. If I then de-select them, click only one of the two black disks, and delete it then suddenly the remaining washer renders correctly and the “no artwork” warning goes away.
…if I then delete the remaining washer and RE-import the original SVG everything works fine & dandy from the outset with no issues, and the cut proceeds normally.
Every time. Upload a washers file, see black disks. Delete one, then the other suddenly appears normally. Delete it, RE-upload the washers file, and everything is completely normal.
…until I upload the next washers file, whereupon I start all over again with the rendering error and No Artwork.
Weird.
