This SEEMS to be a new issue for me, as this has worked in the past. I create a drawing in Corel Draw, it is a vector outline and a .png graphic. When I import it to the UI, the .png graphic shows a mottled background. On the other hand, if I go into the UI and INDIVIDUALLY import the .png and an .svg of the outline, it is fine. I have done this exact same procedure with other creations and it has always worked fine.
*This MAY be a Corel Draw quirk. I opened the combined .svg in Inkscape and resaved in and it LOOKS fine in the UI. Cannot test cut tonight, will try in the AM.
I am confused.
Screen shot from UI:
Source Files in a .zip
Artwork.zip (1.4 MB)
Any thoughts would be greatly appreciated.
