Beginner! Image created and welded in Silhouette. Open in Glowforge app, no longer welded. everything cuts separately. HELP!!!
Would probably need to see the file to make a suggestion, because Modify> Weld in SS should work.
I suspect things didn’t actually get welded, in Silhouette, but we would need to see the file. In general, the Glowforge interface doesn’t not change original files.
I just realized I was not welding it correctly. Thank you all for your help!
Thanks for the answer @Jules and @dklgood ! I’m going to close this thread @jheri.brown - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
